yet another weatherstrip question.....
Old Mar 28, 2003 | 09:17 AM
MY 95's Avatar
MY 95
CI 2-3-4-5-6-8-9 Veteran
St. Jude Donor '05-'06-'07-'08
Default yet another weatherstrip question.....
gonna replace the hatch weatherstrip with GM original.......after reading the archives, Ive seen people say everything from dry place it to glue it to silicone grease to glue. The manual doesnt mention anything but install it........can anyone help me out here???
Old Mar 28, 2003 | 11:22 AM
Red Dwarf's Avatar
Red Dwarf
Default Re: yet another weatherstrip question..... (My 95)
Use search in the left margin & look for weatherstrip. There is a post by no-radio that answers your question. :steering:
Old Mar 28, 2003 | 12:41 PM
MY 95's Avatar
MY 95
Default Re: yet another weatherstrip question..... (lou sylvestri)
thanks Lou :jester
Old Mar 28, 2003 | 03:05 PM
Iroc's Avatar
Iroc
I just replaced mine after it got painted with GM original. It has a upside down "U" groove that has some gunk in it, i guess to keep it stuck in place, its quite sticky. All I did was center it and started with the corners cause you have to press it in firmly in two directions to make sure its down in there good. The corners also help to locate it properly. I used a rubber hammer to gently tap on the top edge to make sure it was fully seated into that U groove. Then evenly work it down on each side. It went down easy, looks great and I have to really press down to get the hatch to latch. Make sure you use some of that grease to keep it protected.
Old Mar 30, 2003 | 07:35 AM
MY 95's Avatar
MY 95
just read that post Lou, thanks.........I just need to decide what to use to lubricate the channel and I'm all set
Old Mar 30, 2003 | 03:41 PM
dbelnap's Avatar
dbelnap
I replaced mine last summer. Almost all posts here indicated NO glue. Use the white guey stuff (silicone grease) that is there already left over from the original weatherstripping. No glue since the w-stripping needs to expand/contract with the temp changes
Regards Doug B
To yet another weatherstrip question.....
