Octane Rating
Old Mar 28, 2003 | 07:01 PM
rmedina's Avatar
rmedina
Default Octane Rating
I've always been a fan of 93octane, but I decided to put some 89 the other day. I have no idea whats going on but my 87 is running strong and has a nice deep mellow sound now. I almost forgot.. I'm getting better fuel mileage too. Whats going on?
Thanks,
Raul
Old Mar 29, 2003 | 09:23 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Octane Rating (rmedina)
Octane is basically a measure of how hard it is to detonate (and how violently) a fuel and hence resist pre-ignition that can be caused by advanced timing, high compression, high temperature, or any of the above.
Pound for pound there is more energy to be had out of lower octane fuel, it ignites more easily and burns more violently. So as such you want to run the lowest octane that you can without any pre-ignition issues. The lowest octane that you can run with your given compression and full timing advance will give you the best performance.
You might see if you can get a scan tool on the car and just make sure that you aren't getting knock counts or timing retard just to be safe. If you are not getting any of these, congrats.
BTW, I bet the car starts faster too doesn't it?
:cheers:
Old Mar 29, 2003 | 09:46 AM
Rob90's Avatar
Rob90
Default Re: Octane Rating (Nathan Plemons)
:iagree: Here is a link to an article that gives you lots of info about fuel and octane http://www.idavette.net/hib/fuel/index.htm
Old Mar 29, 2003 | 10:08 AM
vader86's Avatar
vader86
If your car doesnt need the 93, then dont put it in.
To Octane Rating
