Question about hypertech programming
Old Mar 28, 2003 | 08:08 PM
MagikDraggin's Avatar
MagikDraggin
Cruise-In IV Veteran
Cruise-In V Veteran
Default Question about hypertech programming
I hope this isn't too dumb of a question......but, when a person speaks of having their computer reprogrammed, they ususally mention purchasing one of these programmers for some god-awful amount of money.
My question is, why would anyone actually purchase one of these things for themselves, when (I would presume) one could simply go to a shop that has one and simply pay them a fee for effecting the necessary changes?
Like for example, I want to change the T-stat and put some rear-end gears in. Wouldn't it make money-sense to pay someone else to do the reprogramming, (as long as they don't see "Corvette" and equate that with extra dollar signs)?
I guess I should also ask, just how much as a general rule does it cost to have the 'pooter reprogrammed?
Karl
Old Mar 28, 2003 | 08:10 PM
95AquaC4's Avatar
95AquaC4
Default Re: Question about hypertech programming (MagikDraggin)
Hypertech reads the VIN and stores the stock program within itself. I cannot let you use it without first putting my stock program back into my car, thus "clearing" the Hypertech for further use.
Old Mar 28, 2003 | 08:17 PM
MagikDraggin
Cruise-In V Veteran
Default Re: Question about hypertech programming (95AquaC4)
Ahhh. so that's it? Ok, that makes sense now. So tell me, is a computer illiterate person as I am, going to be able to figure out how to use one of these thingies? And does it "stay" with the car, or do you use it and then simply pack it away for some future use?
I'm not stooopid, mind you, just illiterate ;)
Karl
[Modified by MagikDraggin, 9:19 PM 3/28/2003]
Old Mar 28, 2003 | 08:23 PM
95AquaC4's Avatar
95AquaC4
It's very simple to use. On screen menu, just answer the questions. just upload your program, and place it in your toolbox until you need it again. i should add...don't expect a performance gain with Hypertech. It is however good for changing the speedo for rear gear changes, fan on/off, 160 degree stat, and in my case firming up my shifts and adjusting the shift points.
[Modified by 95AquaC4, 8:25 PM 3/28/2003]
Old Mar 28, 2003 | 08:30 PM
Lone Ranger's Avatar
Lone Ranger
Hypertech is pretty easy to use. It runs a menu question by question and you select yes or no to each question and that is how it sets up the programming. Mkae sure to get the right Hypertech for your '96. Will require a different part # than the one for 94/95 because '96's are OBD-II.
[Modified by Lone Ranger, 7:31 PM 3/28/2003]
MagikDraggin
Cruise-In V Veteran
That's all I had in mind for it. But thanks for the words of warning anyway.
And thanks also Lone Ranger for your input. Always a good idea to get the right one first, hahaha.
It is adviseable to get one of these used (for example, Ebay), or should I look for new?
Karl
[Modified by MagikDraggin, 7:33 PM 3/28/2003]
Old Mar 28, 2003 | 08:34 PM
95AquaC4's Avatar
95AquaC4
Used is fine as long as the owner has put his/her vehicle back to stock. You must make sure of this.
Old Mar 28, 2003 | 08:41 PM
MagikDraggin
Cruise-In V Veteran
Do you mean that you just can't "clear the memory" and start over?
Karl
Old Mar 28, 2003 | 08:47 PM
95AquaC4's Avatar
95AquaC4
Karl
Nope. If we could do that, we could just keep clearing the unit and using over and over again.
Ie: If I wanted to sell you mine, I would have to download my stock program back into my PCM. THEN, the Hypertech could be used on another vehicle. It would simply read the new VIN.
[Modified by 95AquaC4, 8:49 PM 3/28/2003]
Old Mar 28, 2003 | 08:55 PM
MagikDraggin
Cruise-In V Veteran
Gotcha! I really appreciate your time and the info. Now I know which direction I am heading.
A big thanks to you, 95 AQUA C4, and to the Lone Ranger for your input.
Karl
Old Mar 28, 2003 | 08:59 PM
95AquaC4's Avatar
95AquaC4
Karl
:cheers:
Old Mar 28, 2003 | 09:56 PM
Lone Ranger
Karl
Old Mar 29, 2003 | 09:00 AM
silver & red CE's Avatar
silver & red CE
Agree with all the comments about no increae in performance, nice for lower temp fan turn on, stiffer shifts. Another nice feature of the Hypertech (only if you have a 96 or later) is you can purchase a module that will pull engine codes and allow real time scanning of things like MAF flow, ECT, O2 reading, etc. I have one and it works on both my 96 Vette and 96 Impala (even though my Hypertech is specific to my Impala).
edit> oh yea, you can find them used for ~$200, not too bad of a deal.
Eric
[Modified by silver & red CE, 8:01 AM 3/29/2003]
Old Mar 29, 2003 | 04:39 PM
pwrful c4's Avatar
pwrful c4
Karl,Isent my computer to PCMFORLESSand had it reprogrammed.They did a great job,for 98.00 :steering:
To Question about hypertech programming
