Measuring pushrod length, must use solid lifter or...?
Old Mar 28, 2003 | 11:27 PM
Steve85's Avatar
Steve85
Cruise-In V Veteran
Default Measuring pushrod length, must use solid lifter or...?
I have done quite a bit of research on this measuring pushrod stuff. I hear and read you must use a solid lifter, be it roller or not. Or, in the next article there is no mention whatsoever of needing to use a solid roller, or even a mention of the type of lifter being used in the example.
Also, some say you can just go by a witness mark on the valve stem while on the base of the cam (no turning of the engine). Doing this I come up with a 7.400 p/r putting the rocker tip just on the inboard side of the valve stem center. Can I go with that??
I tried taking a reading turning the engine with my hyd. rollers, but when they plunge, there is no way the reading can be accurate throughout the lift range. Then I pull out a set of solid lifters I have(for the same application) and the distance from roller to pushrod seat is a 1/2" different, I don't see how this could give me an accurate reading. So if I need to use a solid roller, which one?
:crazy: :crazy: :crazy:
Old Mar 29, 2003 | 11:57 AM
h rocks's Avatar
h rocks
Default Re: Measuring pushrod length, must use solid lifter or...? (Ski2Tee)
You can get a "checker" spring that's got very little spring pressure.
