'95 a4 transmission leak
Old Mar 29, 2003 | 12:12 AM
vesuvius's Avatar
vesuvius
Cruising
Default '95 a4 transmission leak
My 81k mile 4l60e is leaking from the rear output shaft seal. The archives suggest replacing the output shaft bearings and drive shaft front yoke as well
as changing the bronze bushing in the tail housing behind the rear seal that
supports the yoke. Needless to say, the seal will be replaced.
Other than the leak, the transmission works as designed.
Maybe now is the time to do something to improve or enhance my 'old' tranny. Or is it better to simply stop the leak and leave things alone?
Also, I'll probably let Parker-Robb (a local dealership) do the work unless
someone can advise me as to a specialist, in my area, for this type of work.
Thanks in advance for your reply.
