Help with '90 digital display
Old Mar 29, 2003 | 07:40 AM
SupaVette's Avatar
SupaVette
Default Help with '90 digital display
Can anybody help me with this problem?? When the ignition is turned on the display is fine. As soon as you start the engine, the display starts showing jumbled up charaters and you can't read anything. I've checked all the wires going directly from the display to the ccm but found nothing wrong. Please help as this is quiet a frustrating problem :mad :confused:
Old Mar 29, 2003 | 09:35 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Help with '90 digital display (SupaVette)
Can you post a picture of what it looks like when bad?
It could be a loose connection to the cluster. I had an LCD panel that worked well for a while then went bad, it was the LCD, not the connection
