How much Engine Vacuum should I have?
Old Mar 29, 2003 | 04:35 PM
dgoodhue's Avatar
dgoodhue
Default How much Engine Vacuum should I have?
I hooked up a vacuum guage to an intake port and found I have 17". (stock cam/rockers on 86 L98) I tried spraying carb cleaner to find it but I could not, I have already replace most of my vacuum lines.
I looked through my service manual and could not find any specs. My carroll SC manual claims, I should have 20". Is that correct?
Old Mar 29, 2003 | 04:41 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: How much Engine Vacuum should I have? (dgoodhue)
My stock '86 had 21 inches. I have cast iron heads. I don't know if your alum heads would make a difference
Old Mar 29, 2003 | 05:12 PM
dgoodhue's Avatar
dgoodhue
Would it make that much of a difference that my idle is at ~675rpm? (aftermarkert 52mm throttlebody won't go any lower, because the plate binds with the bore)
Old Mar 29, 2003 | 05:44 PM
bheston's Avatar
bheston
I measured my 92 ealier today due to a problem I'm having. The reading was about 20 inHg. If you take a reading, the needle should be pretty steady at idle and jump when you give it gas. If the neeldle is bouncing all over the place at idle, you got a leak.
Generally speaking for most cars, the vacuum should be about 16 to 22 inHg at idle.
Old Mar 29, 2003 | 09:45 PM
ittlfly's Avatar
ittlfly
Default Re: How much Engine Vacuum should I have? (bheston)
You can probably get a few more inches of Hg by rotating the distributor. However, Your affecting your timing by doing so. 17" of Hg is ok for a stock motor.
[Modified by ittlfly, 6:46 PM 3/29/2003]
Old Mar 29, 2003 | 09:53 PM
kittmaster's Avatar
kittmaster
Guys on a side topic............where did you get your vacuum gauges from? I'm having trouble hunting one down locally and I'd like to measure mine just to see where its at. TIA.........back to our topic
Kitt
Old Mar 30, 2003 | 08:43 AM
dgoodhue's Avatar
dgoodhue
Default Re: How much Engine Vacuum should I have? (kittmaster)
I have a spare autometer boost/vacuum guage that is an interior gauge.
Old Mar 30, 2003 | 08:49 AM
dgoodhue's Avatar
dgoodhue
Default Re: How much Engine Vacuum should I have? (ittlfly)
I have been chasing a rich running car for a while (5 years now) and I have basically limited down it down to a vacuum leak or problem with my ECM harness.
If it is a vacuum leak, I suspect it is my intake manifold because that is when all my problems started happening.
Old Mar 30, 2003 | 07:25 PM
bheston's Avatar
bheston
I have a Sears/Craftsman vacuum gage. I bought it about 10 years ago. Works nice and the instructions are written very well.
To How much Engine Vacuum should I have?
