94 climate control problems
Old Mar 29, 2003 | 11:17 PM
chb88's Avatar
chb88
Default 94 climate control problems
Anyone have any ideas why the temp set on the climate control gets stuck. It seems to be an intermittant problem. If it is set at say 72 degrees, sometimes it will not advance. It seems to always able to get colder though. Any toughts would be helpful.
Craig
Old Mar 29, 2003 | 11:29 PM
don hall's Avatar
don hall
Default Re: 94 climate control problems (chb88)
This a link to a forum thread posted back in 8/2002: http://forums.corvetteforum.com/zerothread?id=371041
Mention is made to a Tech Tip. Go to Tools on the menu bar and click on C4 Tech Tips. There might be additonal info.
Old Mar 30, 2003 | 03:15 AM
Rich_01659's Avatar
Rich_01659
shortly after i bought my 94 the c68 control started to act up. with in a few months it was driving me crazy. i believe once they start to go it is just a matter of time. however it may help to add this is only $125 dollar part from The Last Detail and is one of the EASIEST :) parts to replace. 30 minutes tops. trust me this part is no sweat!
Old Mar 30, 2003 | 09:24 AM
chb88's Avatar
chb88
Default Re: 94 climate control problems (Rich_01659)
Thanks for your help. I will try this and let you know how it works :party:
Old Mar 30, 2003 | 05:05 PM
R23HTC's Avatar
R23HTC
TLD is a good source, but it's only $118 from Jeff. :) I've been having problems with mine as well. I've taken out and cleaned it several times but it's getting to the point where I think I'm just going to replace it. Mine doesn't like to work at all if it gets cold out. :mad
[Modified by R94 LT 1, 4:06 PM 3/30/2003]
To 94 climate control problems
