Mystery Coolant Leak
Old Mar 30, 2003 | 09:49 AM
eighty_duece's Avatar
eighty_duece
6th Gear
Default Mystery Coolant Leak
I own a '95 LT1 which that has developed a coolant leak that I am unable to locate. All the hoses are good, as well as the radiator. I have replace the radiator cap as well without sucess. It does appear to be coming from the water pump either as far as I can tell. In addtion, coolant is flowing into the fill tank (near the winshield) from the bottom hose, not the one from the overflow tank. Anyone got any ideas?
Old Mar 30, 2003 | 09:56 AM
jimswhite92's Avatar
jimswhite92
Default Re: Mystery Coolant Leak (eighty_duece)
Welcome to the forum ----
How about some more symptoms. Are there any drips? Location? Quantity? Did you recently flush the system?
I was able to find a small leak by doing a pressure test on the system.
Let us know
Jim
Old Mar 30, 2003 | 09:59 AM
don hall's Avatar
don hall
.. It does appear to be coming from the water pump either as far as I can tell.
This must be typo.....I think you wanted to say that it does NOT appear........
Pressurizing the coolant system with a pump might help.
Old Mar 30, 2003 | 10:03 AM
eighty_duece
6th Gear
Default Re: Mystery Coolant Leak (jimswhite92)
I did have the coolant system flushed last Sept. and it went inot storage late October. At that time there wasn't any leak. Looking under the car, the leak is a steady steam coming off the metal support frame right under the engine. Had a buddy take a look at it who is good with cars (though he likes dodge) and there is just not enough room to look around. We jacked the vette up to get a view from underneth, but no luck.
Old Mar 30, 2003 | 10:04 AM
eighty_duece
6th Gear
Default Re: Mystery Coolant Leak (Oldman)
yep a typo
Old Mar 30, 2003 | 10:07 AM
eighty_duece
6th Gear
thanks for the tip on the pressure test. I may just take it to an engine repair shop down the road with a good reputation.
Trying to get it ready for sale. Closing on a house in 30 days. Got to get rid of the toy for now. :cry
Old Mar 30, 2003 | 12:49 PM
Sliding's Avatar
Sliding
I had a similar situation and it was water pump tp block gasket.
Also very hard to see but when I took water pump down, I was sure.
Old Mar 30, 2003 | 01:21 PM
eighty_duece
6th Gear
Default Re: Mystery Coolant Leak (Sliding)
Thanks, thought it may have been the water pump, but we could find anything from the front side. Cant get a good look at the back end. I'll have to get dirty next weekend and take a look. Got pretty cold this weekend. Had snow on the ground this morning. I thought winter was over here in Michigan.
Old Mar 31, 2003 | 10:27 AM
Pats90's Avatar
Pats90
St. Jude Donor '14-'15
My 90 convertible was doing the same thing last year. It turned ou to be the water pump. It didn't leak all of the time, a pressure check showed everything ok. It usually leaked after the car was shut off and was cooling down.
Old Mar 31, 2003 | 11:13 AM
Steel Blue 91's Avatar
Steel Blue 91
Default Re: Mystery Coolant Leak (Pats90)
Check the back of the heads where the intake is attached. The intake gasket may be leaking.
Old Mar 31, 2003 | 02:53 PM
zaragoza's Avatar
zaragoza
Veteran: Coast Guard
St. Jude Donor '07 thru '14, '24
Had same problem on my 86,did pressure test & found water pump housing casket was the problem.
Old Mar 31, 2003 | 05:26 PM
bogus's Avatar
bogus
check the surge tank on the firewall, too. mine went bad... and it leaks where the brass collar joins the plastic tank.
Old Mar 31, 2003 | 08:16 PM
eighty_duece
6th Gear
Default Re: Mystery Coolant Leak (bogus)
Thanks all for the tips, I'll let you know what I find.
To Mystery Coolant Leak
