Title pretty much says it. I'm probably going to dyno the LT4 Friday afternoon. What tips /comments do you guys have? I think I'll have some time between runs for AFPR adjustment. Also, they do have WB 02...
Take tools to - adjust fuel pressure, adjust timing. Use same gas that you would be running at the track. Be sure air filter is CLEAN!!!!
Otherwise, have fun. I don't know much about your year but, I will still
guess about 315hp to wheels.
:party: :flag :flag :flag :flag :flag :flag :flag :flag
I would like to see someone dyno an LT4 first with premium gas and then add some 100 octane and see if there is any difference. With a 10.8:1 compression ratio and only 91 gas out here in CA I wonder if that will make a difference.
Otherwise my guess is 345. I got 313 without the hot cam and water pump. Hopefully those will give you at least 30...
