Weather pack connectors?
Old Mar 31, 2003 | 09:33 PM
Strick's Avatar
Strick
Default Weather pack connectors?
Does anyone know how to remove the pins from a broken male weather pack connector? I have the tool, but how do I use it? I also have the replacement plug and wonder how to install the pin once I get it out.
Strick :flag :flag :flag
Old Mar 31, 2003 | 10:36 PM
danno85's Avatar
danno85
Default Re: Weather pack connectors? (Strick)
Slide the tool down over the pin and that will compress the little tabs on
the pin that are holding it in, and with the tool pushed all the way down,
just pull on the wire and the pin will come out (with the wire).
To install, simply push it in from the bottom, no tools required.
Dan
Old Mar 31, 2003 | 10:41 PM
Strick's Avatar
Strick
Default Re: Weather pack connectors? (danno85)
Thanks Danno, sounds easy enough. Time to try it out. :cheers:
:flag :flag :flag
To Weather pack connectors?
