WHEN IS A CLUTCH GOING BAD????
Old Mar 31, 2003 | 09:39 PM
Shaun Patrick's Avatar
Shaun Patrick
Default WHEN IS A CLUTCH GOING BAD????
I took my car in to be inspected for trade in and the guy who drove it said that my clutch is going to need to be replaced. i'm just wondering if the guy is pulling my leg so he can work $700 dollars off my trade in value, then simply run my car through the auction with out ever replacing the clutch. He says that my clutch grabs in an awful high position, also that when i shift into second, the synchros show signs of a problem, because it doesn't always slip into second easily. Are these good indications?? also, the car kind of studders a bit when put into reverse. otherwise, i've never known the clutch to be any different, it's the way it was when i bought it. Somebody give me some help on this. thanks.
Old Mar 31, 2003 | 09:50 PM
Rich_01659's Avatar
Rich_01659
Default Re: WHEN IS A CLUTCH GOING BAD???? (Shaun Patrick)
i believe the clutch in most (all) 94 corvettes will auto adjust to that "high" position. i think that he is trying to run down your trade in value.
good luck
Old Mar 31, 2003 | 10:06 PM
Shaun Patrick
Default Re: WHEN IS A CLUTCH GOING BAD???? (Rich_01659)
thanks for the info, i get the same notion.
Old Mar 31, 2003 | 10:26 PM
sraft's Avatar
sraft
I had a new clutch and flywheel put into mine last fall. It grabed higher than I liked (or expected), but I asked around and discovered that this is normal for 6-spd C4s.
Old Apr 1, 2003 | 08:15 AM
Shaun Patrick
Default Re: WHEN IS A CLUTCH GOING BAD???? (sraft)
ttt
Old Apr 1, 2003 | 09:33 AM
kittmaster's Avatar
kittmaster
A clutch is bad when you are in 5th or 6th gear and you put you foot to the floor the engine rpms rocket to 4000 RPM or greater while no change in the car acceration is felt (maybe a few MPH but not neck wrenching). That is when the cluth is "slipping" and time for a new clutch or you have oil on the clutch face or flywheel.......good luck
Kitt
To WHEN IS A CLUTCH GOING BAD????
