I have a 92 auto LT1 which makes about 300 HP, based on dynos at about 260 RWHP, appropriate for a basically stock engine from that year. I've been wondering what's the cheapest way to get 400 HP out of it and still have a car that can be used as a daily driver. Nitrous is not an option, because I want the power available full-time. Is it possible to get 400 HP by going the route of cam/roller rockers/porting/headers/exhaust, or is supercharging the only reliable option? What would be a realistic minimum budget?
Note added: Is this not a good idea in light of the fact that I have 100,000 miles on the engine? It runs fine now...
Well,the mods I have actually have me probably somewhere around 420-430 at the flywheel,if your referring to flywheel horsepower.My dyno numbers in my sig are before I had the headers put on,and they are rear wheel numbers.
He also has longtube headers and a cat back exhaust (no cats though).Don't think that's gonna pass emission testing. :D
Supercharging will get you there for sure. My buddy did it on his C5, actually two of my buddy's. One still has the stock exhaust and he's putting out close to 650 HP(with a 75 shot), the other is close to 500 at the wheels with a few other mods, but with the S/C alone he managed to get into the mid 12's on street tires, 118mph in the 1/4.
Whats that cost for a C4? I'm guessing $4-5K before you're finished?
Of course, you can do the Hotcam/rr/porting/exhaust route, and just have it reprogrammed every time you do the emissions test. It is possible to DEtune the hotcam to pass emissions, so long as you keep the cats.
Just need to know if you mean flywheel or rear wheel.
If you mean flywheel the Hot Cam and a good set of heads and some headers will get you there. If you're wanting 400 at the wheels you'll need a more aggressive cam but it can still be done very easily without going through the headaches of forced induction.
Nathan, (and others),
Thanks for your replies. I am looking for 400 HP at the flywheel, not rear wheels. What I'm reading here is that with a good top end engine job, 400 HP is quite do-able.
Now, I'm really interested in your estimates of cost...
Depends if you are doing the labor or if someone else is. Also depends on what you choose to do. Do you want it done over a weekend, or do you want to send you heads somewhere to be worked on and have the car down for 3-4 weeks.
If you are paying someone to do it, figure $4-5k turn key which includes programming.
