set the timing.
Old Apr 1, 2003 | 05:48 AM
devilfish's Avatar
devilfish
Default set the timing.
6 degrees before tdc is stock right? Has anyony tried 8-10 degrees?
regards
Old Apr 1, 2003 | 01:33 PM
devilfish's Avatar
devilfish
Default Re: set the timing. (devilfish)
no one?
Old Apr 1, 2003 | 01:37 PM
Steel Blue 91's Avatar
Steel Blue 91
regards
True - stock is 6 degrees. That is where mine is. Others have bumped it - perhaps they will chime in.
Old Apr 1, 2003 | 01:46 PM
rainsux89's Avatar
rainsux89
regards
<BUMP> I'm interested in this too. A search offered up nothing for L98s.
Old Apr 1, 2003 | 01:50 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I run about 8deg BTDC with the stock CalPac and see no knock retard on the scanner.
Any more and the ECM will pull timing near the shift points due to ping; of course I'm running 91/93 octane and have a 160 deg stat & fan sw.
You realy need a scan tool or use trap speed to see when timing is pulled or HP drops off to find the sweet spot.
Old Apr 1, 2003 | 01:51 PM
scorp508's Avatar
scorp508
Default Re: set the timing. (rainsux89)
6* BTDC is the stock setting. Some of us have had luck going higher, some have had to go lower. No 2 engines are identical. The only way to really know yours likes is to slap on a scan tool and watch knock retard through the RPM band or hit the track and watch your MPH between runs.
That being said I started at 6* one night and made a pass. I changed it to 8* and made another pass gaining 1mph. I bumped it again 9* and made another pass gaining another 0.5mph. So with 3* I gained 1.5 mph and about 0.1 in ET. All 3 passes had nearly identical short times and 1/8s, but the last 1/8 was stronger.
Now I just have to wait for ski_dwn_it to come in and yell at me telling me that my proof is flawed. ;) :D
Old Apr 1, 2003 | 04:13 PM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
Default Re: set the timing. (scorp508)
I just changed mine from 6 to 8 degrees.
Engine "feels" a lot better.
AutoXray IS showing a few more knock counts with the 91 octane fuel I can get around here.
I haven't seen much knock retard (3-4 degrees) on WOT runs so I'm going to leave it at +8 for right now.
May sneek it up to 10 if all appears well for the next couple of weeks.
Old Apr 2, 2003 | 01:06 AM
devilfish's Avatar
devilfish
Default Re: set the timing. (VetNutJim)
ok. So start with 6 and look for counts, then start testing higher and higer?
Is knock count all I need to worrie about, or should I test the new settings on the track aswell?
thanks for your answers :)
Old Apr 2, 2003 | 03:25 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
As far as performance goes, I've heard, that retarding a bit will get you more power at low speeds, and advancing will get you a little more at higher speeds... assuming no pinging occurs.
I'm sure all the guys that actually know what they're talking about are :sleep:
Old Apr 2, 2003 | 09:58 AM
scorp508's Avatar
scorp508
Sort of. For all out WOT performance yes for the most part. Keep in mind that moving the base timing will affect all of your daily driving too. Thats why its best to program the timing in the computer, but for WOT performance only using base timing is ok by me.
Old Apr 2, 2003 | 10:50 AM
devilfish's Avatar
devilfish
Default Re: (scorp508)
so whats the deal with base timing vs setting the timin in the computer?
:seeya
Old Apr 2, 2003 | 03:55 PM
scorp508's Avatar
scorp508
Default Re: (devilfish)
Base timing affects the entire RPM range as one unit where setting it in the computer is adjustable for all loads and RPM ranges.
To set the timing.
