PKE and rattle
Old Apr 1, 2003 | 10:55 PM
DennisJ's Avatar
DennisJ
1st Gear
Default PKE and rattle
Is it possible to disable the proximity function but retain the ability to lock/unlock the doors?
I have a rattle in the passenger air cond duct or facia. How is the facia removed without damaging it?
Old Apr 2, 2003 | 10:12 AM
Red Dwarf's Avatar
Red Dwarf
Default Re: PKE and rattle (DennisJ)
You can disable the PKE by holding down the "door" button until you hear/see the door locks cycle. Takes a few seconds. To activate use the same procedure.
If you deactivate the system then the door button will only open the pass/door & the hatch.
The pass vent is removed by first removing the small black louvered portion in the center. Pry it up gently from the bottom. There shud be a couple of 10 mm screws holding the vent .
