LT1 Fuel Presssure Recommendation
During WOT, the PCM ignores the o2 sensors. Assuming a slightly rich mixture (BLMs less than 128), the BLMs will snap to 128. You now have a situation where the base fuel calculation is using BLMs of 128 but with a higher than stock fuel pressure (that the PCM doesn't "know about" since the PCM hasn't been reflashed). By definition, this makes the WOT A/F ratio richer. Since the good General errors on the side of conservatism (read: rich), you now have an overly rich condition that will likely decrease hp.
Of course with enough mods, the engine may be lean and the increased fuel pressure will help. Without a wb o2 sensor to measure the A/F ratio, making adjustments is like playing the lottery. To give you an idea of the mods it takes to get an engine to go lean, look at my sig line. My first set of datalogs after adding the HOT Cam and prior to reflashing my PCM showed I was ~7% lean. Translated to OBD I, this would be equivalent to having BLMs of about 137. Basic mods like an exhaust, open air filter lid, & 52mm throttle body won't get you there.
[Modified by 96GS#007, 9:14 PM 4/2/2003]
My stock FPR read 44 with this test. With LT4 injectors (28lb), LT4 heads, Hotcam, and mostly LT4 PCM programming, my fuel trims would bounce between slightly negative (PCM leaning fuel) to slightly positive (PCM richening fuel).
I got an Aeromotive AFPR and bumped up the pressure to about 49-50psi. Now my fuel trims reads slightly negative (-1 to -5%) all the time. This shows that the PCM does compensate for higher fuel pressures (it has to). But it will make for more consistent Power Enrichment mode fueling (easier to fine tune this way) and I get the "supposed" benefit of finer fuel atomization due to the higher pressure.
Basically, unless you've got the data logging/reprogramming software needed OR you can spend time at a dyno with a wideband O2, then the utilization of an AFPR will just leave you guessing.
