90 - 91 chip
Old Apr 2, 2003 | 11:26 AM
awsumm's Avatar
awsumm
Default 90 - 91 chip
Was wondering if these two years use the same chip ? Also looking for a tuner in GA Thanks !
Old Apr 2, 2003 | 06:26 PM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: 90 - 91 chip (awsumm)
I know it would work in either.. not sure if the program is exactly the same, but they should be interchangeable
Old Apr 3, 2003 | 05:46 PM
awsumm's Avatar
awsumm
Can anyone help on the difference on these two chips? Thanks !
Old Apr 3, 2003 | 07:48 PM
LD85's Avatar
LD85
http://www.cruzers.com/~ludis/p4xref.html#1227165
Old Apr 4, 2003 | 07:55 AM
VetNutJim's Avatar
VetNutJim
Cruise-In I Veteran
They are interchangeble.
Will be some minor changes in some parameters but not enough that you would know without downloading the bins and comparing them.
You DO need the MemCal from the same type car/engine.
ie; a V6 MemCal WILL NOT work on a V8 Camaro/Corvette.
It also CANNOT be reprogrammed to work correctly.
So just make sure what you are getting the ECM/MemCal from has the same number of cylinders as what you want to use it on.
Old Apr 12, 2003 | 03:28 PM
72tccracer's Avatar
72tccracer
Default Re: 90 - 91 chip (VetNutJim)
Anyone have a part # for this chip/ memcal???
Chuck :flag
To 90 - 91 chip
