Need help???
Old Apr 3, 2003 | 11:11 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Default Need help???
I'm installing my Nitrous bottle mounts to the rear floor in my Vette behind the pass seat. One mount (the one closer to the pass seat) is already done and I bolted it through the compartment door. My question is on the second mount...........how much clearance is there between the underside of the floor to the fuel tank? I don't want to hit it when I bolt up this mount.
Old Apr 3, 2003 | 11:21 AM
scorp508's Avatar
scorp508
How are the mounts done? My junky NX ones that came with the kit you put the bolt in through the bottom and tighten the nut on the topside. Just drill very very slowly. :) Actually I don't think the fuel tank reaches underneath there as its behind the rearmost wall of the hatch, but you may hit a cross member. Someone correct me if I'm high on white out.
Old Apr 3, 2003 | 11:38 AM
Mr. Magoo's Avatar
Mr. Magoo
Default Re: (scorp508)
The mounts never came with bolts, I had to go to the hardware store to pick up some. I bought 2" sheet metal screws and washers. The brackets are about 1/2" thick so there is approx 1 3/8" bolt left that I'm going to drill through thr floor.
To Need help???
