Gear Shift Movement
Old Apr 3, 2003 | 12:34 PM
The Bus's Avatar
The Bus
Default Gear Shift Movement
I just had my 92 6 speed vette for it's first outting of the year. I jumped on the gas in first and noticed that the gear shift moved up about a 1/2 an inch. It did the same thing when I jammed it in second and third. Is this normal and I never noticed it before?
Old Apr 3, 2003 | 06:49 PM
1991Z07's Avatar
1991Z07
Default Re: Gear Shift Movement (The Bus)
It is usually indicative of the driveline beam being loose.
If you want to save some money over the beam-plates that the ZFDoc produces, get some 3/16" sheet steel and cut some plates that will span both bolts (front & rear, top & bottom). Drill them out and install them between the bolt & the beam.
What the plates do is distribute the force of the bolts across a wider surface. It makes a big difference in the stability of the car as well. Many have reported less rear-end kick-out under hard acceleration with them installed.
Old Apr 4, 2003 | 07:27 AM
The Bus's Avatar
The Bus
The bolts on the drive beam support seem to be tight. Could the bolt holes be elongated? Or is there any other area I should check?
Old Apr 4, 2003 | 10:01 AM
1991Z07's Avatar
1991Z07
Let me see if I can explain this without visual aids....
When the bolts for the support beam are over-torqued, the beam actually pinches in at the point where the bolts contact the beam. When this happens, you have only a small point of full contact between the beam and the transmission.
GM added an RTV-type substance between the beam and the trans at the factory to help fill the voids and stabilize the driveline beam. Originally, it bonded the beam to the transmission, and I remember the mechanic removing it for the first time cussing up a storm because it wouldn't come out. This substance gets removed over time as the beam is removed/installed for service.
If you add a beam-plate to the bolts, you take the point-loads and spread them out over a wider space. This makes the beam, which is aluminium, stronger. The forces are distributed, and the beam will not flex under loads.
Make any sense now?
To Gear Shift Movement
