Shock question
Old Apr 5, 2003 | 01:52 PM
62C1's Avatar
62C1
Default Shock question
I'm replacing the shocks on my 92 LT1. The manual is pretty clear about the procedure except on the rear where it talks about maintaining the ride height. I know I have to support the hub when removing the rear shocks but is there something else that needs to be done to maintain the ride height?
Old Apr 5, 2003 | 03:36 PM
JasonL's Avatar
JasonL
Default Re: Shock question (62C1)
You don't have to maintain ride height, just don't let the suspension hang at full droop. The shock prevents the suspension from extending any further...so if you don't take some of the load off, a nut may go flying when you loosen it. Hope that helps.
