Gear Shift Vertical Movement
Old Apr 5, 2003 | 03:39 PM
The Bus's Avatar
The Bus
Default Gear Shift Vertical Movement
I previous had listed the same topic two days ago. I thought the gearshift only moved up during hard acceleration ; however I just was out and observed that it moves up the 1/2 inch as soon as I give it any gas. Thought it was the support beam , what do you guys think?
Old Apr 5, 2003 | 03:53 PM
95AquaC4's Avatar
95AquaC4
Default Re: Gear Shift Vertical Movement (The Bus)
Normal :yesnod:
Old Apr 5, 2003 | 04:26 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
I would get under it and retorque the toque arm bolts. Mine hardly moves at all.
Old Apr 7, 2003 | 11:32 AM
NavyVet's Avatar
NavyVet
Like he said - check the bolts on the c-beam - if loose, shifter moves up & down. :flag
Old Apr 7, 2003 | 03:30 PM
95AquaC4's Avatar
95AquaC4
Default Re: Gear Shift Vertical Movement (NavyVet)
Hmmm. Interesting. I had an RS Camaro that did this for years. :confused: was told it was normal with the natural movement of the drivetrain.
To Gear Shift Vertical Movement
