Wires and coil do they make a difference?
Old Apr 5, 2003 | 05:14 PM
91superram's Avatar
91superram
Default Wires and coil do they make a difference?
Do wires and a coil make a difference in performance in a TPI L98
and which is the best
Old Apr 5, 2003 | 05:22 PM
vader86's Avatar
vader86
Default Re: Wires and coil do they make a difference? (91superram)
It makes a difference if you can make power at high rpms, like if you have Superram or Miniram. HEI has a hard time making good spark up there, but with the TPI it doesnt matter since the TPI doesnt need it anyway. It chokes out before the HEI starts sputtering.
I'm using MSD 8.5mm Superconductor wires, id probably be using an Accel cap/coil or MSD coil when i get the SR.
Old Apr 5, 2003 | 05:28 PM
scorp508's Avatar
scorp508
The stock coil is fine on a stock car not needing high RPM spark.
Old Apr 5, 2003 | 05:42 PM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: (scorp508)
If you're running around 6k RPM or so, a higher output coil will just be a patch. The only real fix is to switch to a Capacitive Discharge Ignition system like an MSD setup. Transistorized ignitions just simply cannot recover in time to generate a full spark at 6k RPM. The wires will help some if you can find some low resistance wires, but again, it's just a patch. If you're not pushing up around 6k RPM, save your money and go stock.
Old Apr 5, 2003 | 06:55 PM
91superram's Avatar
91superram
Default Re: Wires and coil do they make a difference? (vader86)
Im running a superram with a crane coil and stock wires
should I upgrade to MSD wires and coil. I must be losing high
rpm spark.
Old Apr 5, 2003 | 07:43 PM
CorvetteZ51Racer
What RPM are you shifting at? Unless you're near 6k RPM at shift, you're fine.
Old Apr 5, 2003 | 07:50 PM
EDMGUY's Avatar
EDMGUY
I'm a Taylor wire fan.Love the heat shealds and they are for PRO's great replacement .My 2 cents :flag :cheers: :cheers:
Old Apr 5, 2003 | 07:54 PM
91superram's Avatar
91superram
Default Re: Wires and coil do they make a difference? (CorvetteZ51Racer)
Im shifting at 5800 rpm and it seems fine there is no break down
Old Apr 5, 2003 | 07:58 PM
CorvetteZ51Racer
Well, it sounds like you're on the border of being able to stock with the stock HEI ignition. You might be fine for now, but if you do heads or cam or something that raises your shiftpoint at all, you'll likely need to switch to a CDI ignition.
Old Apr 5, 2003 | 10:59 PM
J Z06's Avatar
J Z06
I ran a completely factory ignition on my 383 until a recent DFI swap. I still think the 6-al box is un-necessary...but it's there.
I make about 440 hp at the crank and I never had an ignition problem(other than wear and tear) with msd wires and stock parts.
To Wires and coil do they make a difference?
