85-85 A/C Compressor Bolt
Old Apr 7, 2003 | 01:34 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
Default 85-85 A/C Compressor Bolt
Anybody ever replace the Torx bolt at the bottom of the A/C compressor. The one with the flat to slip passed the notch in the AC pulley. Where did you get it? My parts book shows 14084314, but the dealers I've contacted can't help.
Old Apr 7, 2003 | 04:07 AM
weekendwrench's Avatar
weekendwrench
Default Re: 85-85 A/C Compressor Bolt (Ray Quayle)
When I checked I was told the bolt is no longer available. I just reused mine but could not get it real tight as the torx was a bit stripped. I used locktight when I installed it.
Old Apr 7, 2003 | 08:34 AM
VetteRacer282's Avatar
VetteRacer282
If you need one I can check what shape mine is in.
Email me if you need one.
Matt
Old Apr 7, 2003 | 09:13 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: 85-85 A/C Compressor Bolt (VetteRacer282)
It has a torx head in it? :confused:
Why not just get a standard bolt and notch the head out?
Old Apr 7, 2003 | 04:27 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Default Re: 85-85 A/C Compressor Bolt (CentralCoaster)
Guys,
Thanks for the replys.
CentralCoaster, I'm not sure if a standard hex head bolt will not interfere with the clutch or pulley. I will give it a try though. I thought I'd ask though as some folks have eliminated their A/C and may have the bolts around.
VetteRacer282, You have mail.
Old Apr 8, 2003 | 08:49 AM
CentralCoaster
Maybe I'm mistaken...I thought you were referring to the lower bolt that goes into the front side of the ac casing and threads into the cylinder head(?). perhaps my 85 is different from yours.
Good luck :cheers:
Old Apr 8, 2003 | 09:08 AM
tommelton's Avatar
tommelton
You can get an allen head bolt that will work the same as the original torx head bolt. That is what I had to do.
If you try to use a normal hex head bolt, there is really not enough room to get a socket on the head of the bolt, unless you have a really thin-walled socket.
Tom Melton
82 CE
86 Z51 Coupe
Old Apr 8, 2003 | 11:59 AM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Default Re: 85-85 A/C Compressor Bolt (tommelton)
CentralCoaster, I think we're talking about the same bolt. I'll probably end up taking Tom's suggestion and using an allen head bolt.
Thanks for all the responses.
To 85-85 A/C Compressor Bolt
