'95 Rear brake upgrade?
Old Apr 7, 2003 | 04:20 PM
JayH's Avatar
JayH
Default '95 Rear brake upgrade?
It's time to do wheel bearings and brakes in the rear and the search doesn't seem to be working, so....
What's a good upgrade for rotors and pads in the rear? Powerstop? Stillen? and where to get them? What about rebuilding/upgrading the calipers?
Thanks,
Jay
Old Apr 8, 2003 | 03:34 PM
JayH's Avatar
JayH
Default Re: '95 Rear brake upgrade? (JayH)
hmmmmm, OK. What bout the Baer discs for the C5? same bolt pattern? same rotor size?
Any good quality pads any of you recommend?
Jay
Old Apr 8, 2003 | 04:05 PM
Jeffvette's Avatar
Jeffvette
From: No more yankee my wankee, the Donger is tired!
Go with either hawks or EBC all around. Flush with new fluid.
Do you track the car at all, or do you daily drive???????
Depending on the mileage it might be worht while to rebuild the calipers.
Old Apr 8, 2003 | 05:12 PM
JayH's Avatar
JayH
Default Re: '95 Rear brake upgrade? (Jeffvette)
Thanks Jeff, it's a daily driver with 115k on the odometer. EBC, Hawks - got a web site, never even heard of 'em...
Jay
Old Apr 8, 2003 | 05:16 PM
95Redsled's Avatar
95Redsled
I was preparing to do this to my 95 also, and bought a set of C5 front and rear calipers before I found out that by using the C5 rear caliper you have to disconnect the emergency brake. Personally I don't want to sacrifice my emergency brake, so when I upgrade my fronts I will probably reuse my stock rears. Baer does make an Eradispeed rotor for both the front and rear, not positive about the others. Good luck :chevy
Old Apr 8, 2003 | 06:18 PM
Jeffvette's Avatar
Jeffvette
Sending a email
To '95 Rear brake upgrade?
