Need to replace washer/clip thing from front break assembly
Old Apr 8, 2003 | 01:57 PM
Crispyc21's Avatar
Crispyc21
Default Need to replace washer/clip thing from front break assembly
http://content.madirect.com/img300/fr1123.jpg
I need to get that little washer/clip thing in the picture above. If I purchase it using Mid-America it will cost $15 after shipping. Would Pep-boys or a car place like that carry that or should I just bit the bullet and get it? If I purchase from a store what is the size?
[Modified by Crispyc21, 2:00 PM 4/8/2003]
Old Apr 8, 2003 | 02:07 PM
don hall's Avatar
don hall
Default Re: Need to replace washer/clip thing from front break assembly (Crispyc21)
..need to get that little washer/clip thing in the picture above.
Are you asking about the "E" clamp, or the part to the left of the clamp? If you need just the "E" clamp, they are available at most any auto store.
Old Apr 8, 2003 | 02:41 PM
Crispyc21's Avatar
Crispyc21
Default Re: Need to replace washer/clip thing from front break assembly (Oldman)
I need that "E" clamp that goes onto the end of the bolt that's right above it. Is there a size I need to request?
Old Apr 8, 2003 | 02:46 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
My bet is your GM Shop manual says to replace at least the pin and the E-clip.
Old Apr 8, 2003 | 02:51 PM
don hall's Avatar
don hall
Take the bolt to the store with you, and they will find a match.
To Need to replace washer/clip thing from front break assembly
