Fail open Thermostats
Old Apr 9, 2003 | 09:51 AM
The Bus's Avatar
The Bus
Default Fail open Thermostats
I was watching Two Guys Garage TV show a few months back and they were replacing a thermostat in a car that when it failed it failed open instead of closed like most do. I'll be changing my coolant and I want to replace the thermosat also. My local parts store didn't carry them. Does anybody know the brand or if the big auto store chains carry them.
Old Apr 9, 2003 | 10:18 AM
don hall's Avatar
don hall
Default Re: Fail open Thermostats (The Bus)
http://www.motoradusa.com/products/failsafethermo/
Old Apr 9, 2003 | 07:14 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
:cheers: As far as I know, any GM thermostat replacement should fit any C4. I think the built in thermo housing and thermo is a C5 debacle.
Thermo should cost les than $ 5
:steering:
Old Apr 9, 2003 | 09:30 PM
CFI-EFI's Avatar
CFI-EFI
It has been my experience, that the good (not super duper) name brands, fail in the open position. The Doles, Stants, etc. The super cheap, fail closed. Although it's been a couple of years, I would recommend spending $5.00 or a little more, than less. Over $10.00 is a rip. Good luck and...
RACE ON!!!
Old Apr 10, 2003 | 07:27 PM
konroh's Avatar
konroh
Default Re: Fail open Thermostats (jackdaroofer)
:steering:
the lt1 requires a specific style of thermostat, different than a standard one...i think mine was about $10ish
Old Apr 10, 2003 | 09:01 PM
CFI-EFI's Avatar
CFI-EFI
Default Re: Fail open Thermostats (konroh)
MY comments and pricing oppinions, apply ONLY to the older conventional, thermostats. I have no knowledge or experience with LTs. Good luck, and...
RACE ON!!!
Old Apr 11, 2003 | 05:17 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Default Re: Fail open Thermostats (CFI-EFI)
The MotoRad ones are the ones that I've used, and they definitely work! Worth every cent you might pay for one, and it's the cheapest insurance anyone could get. I cringe whenever I think about what will happen if my thermostat failed in the closed position; what's the worst that happens if it fails in the open, no heat? Big deal! It's better than having to replace a set of aluminum cylinder heads that cracked because the car overheated due to a failed thermostat!!!
Can you tell what I was doing this winter? :mad
[Modified by TheCorvetteKid, 10:17 PM 4/11/2003]
To Fail open Thermostats
