Reusing OEM disc brake pads
Old Apr 9, 2003 | 11:56 AM
c4cruiser's Avatar
c4cruiser
Default Reusing OEM disc brake pads
Three years ago when I installed a set of Hawk HPS pads on my 92, I kept the OEM pads that measure out to have about 85% left on the material. Over that time the OEM rotors have been pretty much been used up from some autocross and occasional track days.
I want to replace the rotors before the upcoming summer caravan to Bowling Green. Can I safely reinstall my OEM pads on the new rotors? I've read here that you should break in new rotors with old pads (and vice-versa) but I would like to leave the original pads in place. OK??
Old Apr 9, 2003 | 01:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: Reusing OEM disc brake pads (c4cruiser)
When I did my front brakes one rotor was shot so I installed new pads & rotors.
You should be able to use old pads with new rotors; you shouldn't need to bed them as the pads are already broken in.
You might want to put a little black RTV on the back of each pad as an anti-rattle measure.
Old Apr 9, 2003 | 02:32 PM
ConeKLR's Avatar
ConeKLR
Default Re: Reusing OEM disc brake pads (65Z01)
There is no reason why you can't do it.
Old Apr 9, 2003 | 03:34 PM
kittmaster's Avatar
kittmaster
Default Re: Reusing OEM disc brake pads (ConeKLR)
:withstupid:
Old Apr 9, 2003 | 04:16 PM
antenna's Avatar
antenna
"I've read here that you should break in new rotors with old pads"
Do you figure that they have a big box of old pads at the Vette factory so they can put them on the new cars so the new rotors will break in properly?
[Modified by antenna, 9:17 PM 4/9/2003]
To Reusing OEM disc brake pads
