Before & After injector cleaning data
Old Apr 9, 2003 | 04:22 PM
LD85's Avatar
LD85
Default Before & After injector cleaning data
http://www.cruzinperformance.com/inj...=304071-304078
:cool: :cheers: :cool: :cool: :cheers:
[Modified by ld85, 4:23 PM 4/9/2003]
Old Apr 9, 2003 | 07:31 PM
JCAIRE2's Avatar
JCAIRE2
Default Re: Before & After injector cleaning data (ld85)
Looks good :thumbs: :cool: :cheers:
Old Apr 9, 2003 | 07:35 PM
J Z06's Avatar
J Z06
I used Wilson Manifold down in florida. I didn't get any reading like that sadly. The people who installed my DFI recommended them highly.
That does look quite good though! I've heard nothing but good things about Cruzin performance.
Old Apr 9, 2003 | 07:36 PM
Wadoka's Avatar
Wadoka
St. Jude Donor '03-'04
Cruise-In 1-2-3-4-5 Veteran
Default Re: Before & After injector cleaning data (JCAIRE2)
Looks like #1 isn't pulling its weight! But cool information, neatly presented.
Old Apr 9, 2003 | 07:38 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
They do a great job and Rich is super to deal with.
Old Apr 9, 2003 | 07:46 PM
bogus's Avatar
bogus
cool! how much???
Old Apr 9, 2003 | 08:07 PM
LD85's Avatar
LD85
Default Re: Before & After injector cleaning data (bogus)
cool! how much???
Rich has prices on his site but,, to rebuild and flow match cost $96.30 including shipping! :thumbs:
Here is some more cool info on the max pressure I should use!
QUOTE:
Larry, the safe limit for these injectors should be limited to about 60 psi.
The injectors are tested at 43.5psi. If you raise the pressure and want to find the new flow rate you can use the following formula:
Divide the new pressure by the old pressure. Next find the square root of this number. Finally, multiply the old flow number by the square root number and the result will be the new flow rate at the higher pressure.
Here is an example: 50psi divided by 43.5psi = 1.1494; The square root of 1.1494 = 1.0721; 1.0721 x 25.14lb/hr (old flow rate of injector) = 26.95lb/hr (new flow rate of injector at higher pressure). END QUOTE
So 60psi divided by 43.5psi = 1.3793; The square root of 1.3793 = 1.1744; 1.1744 x 25.14lb/hr (old flow rate of injector) = 29.52lb/hr
New Walbro 340 pumps up to 80 PSI so if 60-psi is "safe" then I saved money on the 30# injectors. (for now)
:crazy: :yesnod: :lol:
[Modified by ld85, 8:40 PM 4/9/2003]
Old Apr 9, 2003 | 09:09 PM
65Z01's Avatar
65Z01
Rich has 48hr turn-around time so with 2-day shipping each way you would have them back within a week.
Old Apr 9, 2003 | 09:24 PM
ittlfly's Avatar
ittlfly
Default Re: Before & After injector cleaning data (65Z01)
:iagree:
Very good guy to deal with.. :cheers:
[Modified by ittlfly, 6:26 PM 4/9/2003]
Old Apr 9, 2003 | 09:31 PM
bogus's Avatar
bogus
Default Re: Before & After injector cleaning data (ittlfly)
sounds like a good investment in used injectors... let him match'm and life is great!!!
Thanks for the info!!! :cheers:
Old Apr 9, 2003 | 09:35 PM
Aggravated4life's Avatar
Aggravated4life
Hey LD,
Nice to see that post.I have Rich on file for future works and will definitely use him as his work has had nothing but praise on the forum.
Keep me posted via email when its almost time to fire the new motor up.Wish I could be up there when it happens.
Old Apr 9, 2003 | 10:02 PM
LD85's Avatar
LD85
Default Re: Before & After injector cleaning data (Bill's86Coupe)
I assure you I will make it down your way this summer! :yesnod: :D :cheers:
To Before & After injector cleaning data
