underhood lights?
Old Apr 11, 2003 | 07:20 AM
ScottsLS3's Avatar
ScottsLS3
Default underhood lights?
Hi,
if i splice a small toogle switch in either one of these wires would it turn off both lights? has anyone done this? i know the sell a kit but its way over priced? is it that simple or do i need to do more?
[Modified by ScottsLT1, 7:23 AM 4/11/2003]
[Modified by ScottsLT1, 7:24 AM 4/11/2003]
Old Apr 11, 2003 | 07:32 AM
Tom Piper's Avatar
Tom Piper
Default Re: underhood lights? (ScottsLT1)
Hi,
To use that method, you would have to put a toggle switch at each light.
Tom Piper
Old Apr 11, 2003 | 07:41 AM
ScottsLS3's Avatar
ScottsLS3
Default Re: underhood lights? (Tom Piper)
any place i could put just one to shut off both?
Old Apr 11, 2003 | 08:07 AM
Steel Blue 91's Avatar
Steel Blue 91
If you follow the wires back, they will converge at a 10amp fuse (in holder) in front of the DS wheel well. You could splice a switch in before the fuse holder or simply remove the fuse.
Old Apr 11, 2003 | 08:12 AM
ScottsLS3's Avatar
ScottsLS3
Default Re: underhood lights? (Steel Blue 91)
Great Thanks.........i love you guys :cry :grouphug: :cry ;)
Old Apr 11, 2003 | 10:06 AM
ittlfly's Avatar
ittlfly
I just pull the fuse. Like someone said, it's in a 2 wire weather pack connector next to the air pump. a lot cheaper than a switch and less hassle than cutting into wiring. :D
Old Apr 11, 2003 | 11:44 AM
Chefskeez6's Avatar
Chefskeez6
I'm glad you asked this i am planning on doing the same thing real soon, hopefully before the snow melts. Scott you definetely have a car i would like to own, a perfect example of a supercharged LT1. How long was that car out of operation, i would love to do something like you did but i have been waiting all winter long to drive it and the last thing i want to do is start taking it apart now.
Old Apr 11, 2003 | 12:59 PM
Vetterin's Avatar
Vetterin
Can't you just disconnect/unplug the wires like I do in my 85 or are the newer cars wired differently? I know it only takes me about 10 seconds to disconnect/reconnect mine.
[Modified by Vetterin, 12:03 PM 4/11/2003]
Old Apr 11, 2003 | 01:00 PM
Greg Johnson's Avatar
Greg Johnson
You can do this. I just uplug mine.
Old Apr 11, 2003 | 01:03 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Indeed you can do the job without the "kit" by pulling the fuse or installing a switch.
I chose the kit with it's three weather pack connectors, switch, cable and spiral wrap for a very neat and stealth job.
Old Apr 11, 2003 | 01:55 PM
TA's Avatar
TA
Default Re: underhood lights? (Vetterin)
Thats what I do :yesnod:
Old Apr 11, 2003 | 03:40 PM
C10 JDR's Avatar
C10 JDR
Default Re: underhood lights? (TA)
and me :)
Old Apr 11, 2003 | 03:51 PM
J Z06's Avatar
J Z06
dis-connect them(follow the wires) when you want them off, re-connect them when you want them back on.
works like a charm. :cheers:
Old Apr 11, 2003 | 04:23 PM
ScottsLS3's Avatar
ScottsLS3
Default Re: underhood lights? (Jay D 90 383)
ive had them disconnected on both sides for a while but onetime i needed them on at night i had a helll of a time finding the connections ....in the rain :cuss :mad :cuss . I'll do the fuse but i'd like to get a switch in there for ease of operation. :yesnod:
To underhood lights?
