4+3 OD ?
Old Apr 11, 2003 | 03:38 PM
Curveit's Avatar
Curveit
Default 4+3 OD ?
Does anyone know how to defeat the auto engage of OD on my '86 4+3?
I prefer a manual operation only. Thanks
:chevy
Old Apr 11, 2003 | 04:07 PM
scorp508's Avatar
scorp508
Default Re: 4+3 OD ? (Curveit)
Replace the wire going to your OD solenoid with a manually switched 12V source. :yesnod:
Old Apr 11, 2003 | 05:02 PM
Curveit's Avatar
Curveit
:thumbs: Thanks!!! That was too easy. I'm just never sure what the ECM
is gonna do when change something, so I thought I'd ask.
:chevy
Old Apr 11, 2003 | 05:35 PM
scorp508's Avatar
scorp508
You'll still see the Overdrive light going on and off as the ECM will still think it has control.
Safety factors you will lose and should consider when you go to manual control....
1. O/D is normally never engaged until 122* (F) coolant temp.
2. O/D shouldn't really be used in 1st in 99.999% of cases.
3. The ECM prevents downshifts over 4000 RPM.
To 4+3 OD ?
