Need more clutch help!!
I didn't think hydraulic clutches were adjustable.
I know alot of the guys on here have installed the same clutch in their cars. Was there 1/4" of space between the bearing and press plate?
Sturtzy
Anyway, the specs suggest "approximately" 1/4", and further state that the bearing is self-aligning.
[Modified by Oldman, 2:02 AM 4/12/2003]
What was wrong with the clutch unit you recently replaced? you had a noise??
They do not sell the DF disk seperately, so I ordered the same DF clutch kit and a new Hayes billet steel flywheel. The instructions with both say to provide 1/4" spacing between the fingers and throwout bearing. I am aware there is no way to adjust a hydraulic clutch, but I am confused about these instructions.
I wonder if the instructions are all the same (generic) for all of their clutch kits and this only applies to a linkage type clutch and not the hydraulic. The reason for this spacing is that with the centrifigal assist clutch the weights on the fingers cause them to move outward as the RPMs increase, thus increasing the holding power. When this happens if the throwout bearing is right there the fingers will press on it possibly unloading the clutch.
My assumption is that the force of the fingers will push the throwout bearing back on a hydraulic set-up. This would not be true in a manual set-up as the linkage would not give, requiring the spacing.
I am just looking for someone who has installed a hydraulic clutch and can verify that this does not apply to my set-up before I bolt the tranny back in.
I see no way to maintain the clearance since the throwout bearing only goes back as far as the fingers press it back.
http://www.haysclutches.com/haysfaq.html
Sturtzy
[Modified by sturtzy85L98, 11:24 PM 4/13/2003]
Dale
Kind of confusing if you have no experience with a hydraulic clutch.
Sturtzy
