Hand Shifter removal-boot replacement
Old Apr 12, 2003 | 09:23 AM
georgechuckus's Avatar
georgechuckus
Default Hand Shifter removal-boot replacement
Guys, I posted this in the general info and saw it getting passed overso I cut and pasted it here.
I'm Restoring the leather boot/cover on the shifting rod.
How the heck do you get the hand shifter off the shifter shaft?
Tried pressing the buton and cant find a release.
Charlie
Old Apr 12, 2003 | 09:34 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: Hand Shifter removal-boot replacement (georgechuckus)
Ok, I will assume it's an automatic.
1st, pry out the button on top. then you will find a snap ring holding the shift **** in place. Remove the snap ring and pull the **** off, then proceed with the rest of the shifter console plate removal.
Old Apr 12, 2003 | 09:40 AM
georgechuckus
Default Re: Hand Shifter removal-boot replacement (Mr Mojo)
MANY THANKS !
Simple...
C
To Hand Shifter removal-boot replacement
