TORQUE CONVERTER LOCK UP SWITCH??
Old Apr 13, 2003 | 05:26 PM
richy rich's Avatar
richy rich
Default TORQUE CONVERTER LOCK UP SWITCH??
HEY DOES ANYBODY KNOW HOW TO OR CAN DIRECT ME TO THIS MOD.IT INVOLVES A SWITCH WIRED TO THE ADSL THAT WILL LOCK UP THE CONVERTER WHEN U FLICK THE SWITCH.-GIVING U MORE POWER ON A DYNO OR MORE M.P.H. AT THE TRACK!THANKS .
Old Apr 14, 2003 | 04:39 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: TORQUE CONVERTER LOCK UP SWITCH?? (richy rich)
If your ALDL pin "F" is the TC lockup status terminal, like with my 700R/4, connect the switch between pin F & pin A.
You can also connect a mini-LED in series with a 2.2 kOhm resistor across those pins to have a visual indication of TC lockup status; when the LED is lit the TC is not locked & when out the TC is locked.
Old Apr 14, 2003 | 03:52 PM
richy rich's Avatar
richy rich
that does help but which pronge is f or A.by the way do u run this mod.how come others don't?
Old Apr 14, 2003 | 05:00 PM
93 ragtop's Avatar
93 ragtop
I to have wondered why others dont do this. Can it cause any other problems by running it locked?
To TORQUE CONVERTER LOCK UP SWITCH??
