Radio install problems. Electrical geniuses needed
Old Apr 13, 2003 | 09:29 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Radio install problems. Electrical geniuses needed
3 years ago I yanked the Bose and put in a Pioneer CD. Everything was rewired at the time. Stereo crapped out last week, so I bought another Pioneer(4 year warranty this time). All the leads are the same color as on the previous unit, so I just cut the wires at the back of the old unit and spliced in the new harness. The new stereo won't turn on, and I've lost the door/headlight chime. The chime got extremely weak before it finally just disappeared. You only need 3 wires to get the stereo on. Red for switched ignition, orange for constant 12V, and black for ground. These 3 are hooked up correctly. I checked the fuse for the radio and it's fine. I'm assuming there's a connection between the radio not working and the chime quittting. But what is it? Thanks
Old Apr 13, 2003 | 09:51 PM
robtx's Avatar
robtx
Default Re: Radio install problems. Electrical geniuses needed (flyersfan1088)
Did you check your connections with a volt meter.. to make sure your getting your 12v and the switch is working?
Old Apr 13, 2003 | 10:33 PM
flyersfan1088
Default Re: Radio install problems. Electrical geniuses needed (robtx)
No, I don't have access to a voltmeter right now. The thing that gets me is the old radio had power. 10 minutes later, after splicing in the new harness, no power. :confused:
Old Apr 13, 2003 | 10:38 PM
jimswhite92's Avatar
jimswhite92
You may have grounded out something while splicing. I'll look at the wiring diagram and get back with you.
It's an 86 ... right ?
Jim
Old Apr 13, 2003 | 10:43 PM
hippy's Avatar
hippy
Default Re: Radio install problems. Electrical geniuses needed (jimswhite92)
Did you check the 15 amp ctsy/clk fuse? This is from my 89 but I would think it is the same amp/name of the fuse.
Old Apr 13, 2003 | 10:44 PM
jimswhite92
check the CTSY/CLK fuse. Two fuses feed the radio. One is constant 12V and the other is swiched with the ignition switch.
Jim
Old Apr 13, 2003 | 11:14 PM
flyersfan1088
Default Re: Radio install problems. Electrical geniuses needed (hippy)
And we have a winner!!!!!!! The clk/ctsy fuse was blown. Now I have chimes AND a radio! While I was in there I noticed two different single wire connectors that weren't hooked up to anything. At first I thought they were supposed to be hooked together, but they don't fit. I can now add these to my list of connecters that are disconnected and I don't know what they do. Oh well.
Thanks guys!!!
Steve
To Radio install problems. Electrical geniuses needed
