Muff Elim
Old Apr 14, 2003 | 09:53 AM
Polar LT4's Avatar
Polar LT4
Default Muff Elim
I currently have an LT4 with a stock exhaust. I want to put on some eliminators, but maintain the ability to reinstall my mufflers. Would it be possible to cut off the mufflers & weld a clamp/flange/etc. so I can interchange the elims & stock exhaust at will?
Old Apr 14, 2003 | 10:01 AM
FoolCrzy's Avatar
FoolCrzy
Default Re: Muff Elim (Polar LT4)
I considered doing the same thing. I ended up buying a stock exhaust off a LT1 car that had already had the Mufflers removed. I'd suggest that, so you have your stock exhaust for future use. :cheers:
BTW, it sounds mean..
Old Apr 14, 2003 | 01:38 PM
_freakmonkeydogboy_'s Avatar
_freakmonkeydogboy_
I will have a stock exhaust off my '95 w/ elims on it, if you're interested let me know, we can work something out... :D
Old Apr 14, 2003 | 02:03 PM
tuband's Avatar
tuband
Cruise-In I Veteran
Yes, a good exhaust shop should be able to accommodate this. Try to get the wide, stainless steel clamps ... it will make changing much easier.
I did this on my '94 when I changed from stock to elims. I later "graduated" to Corsas.
To Muff Elim
