head bolt torque
Old Apr 14, 2003 | 11:38 AM
devilfish's Avatar
devilfish
Default head bolt torque
what is it for my 113 alu heads
the manual says
smal bolts 88NM
large bolts 101NM
right?
And must I tight the bolts in several runs, starting with littel torque and then climb?
thanks
ohh and how much sealent on the bolts, is the threads enough?
regards
Old Apr 14, 2003 | 12:27 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: head bolt torque (devilfish)
My '88 GM Shop Manual says to:
-apply GM sealent #1052080 or equivalent to the head bolt threads
-install all head bolts finger tight
-torque in several steps to 60-75lb-ft torque in the specified order:
<-Front
.....13......5.......2.....10
......O......O......O......O
17......9......1.......6.....14
.O......O......O......O......O
16.12..8..4..3..7..11..15
.O..O..O..O..O..O..O..O
For my '88 the diagram shows two different lengths of head bolts but has only one torque spec for either bolt.
The torque numbers for #113 heads in my '88 L98 may not apply to your '90 since since your pistons develope more compression but the tightening sequence should be good.
Old Apr 14, 2003 | 01:37 PM
devilfish's Avatar
devilfish
Default Re: head bolt torque (65Z01)
ok strange that my hayes manual says that the short head bolts shoul be 88NM and the long 101NM...
Old Apr 14, 2003 | 01:39 PM
scorp508's Avatar
scorp508
My ARP head bolts with ARP thread sealer are all torqued to 70 ft/lb in 4 steps.
1. Snug
2. 50 ft/lb
3. 60 ft/lb
4. 70 ft/lb
Old Apr 14, 2003 | 01:41 PM
devilfish's Avatar
devilfish
Default Re: (scorp508)
im using stock bolts. Should I thigh them all to 100NM or should I follw the haynes manual?
And how much sealent did u use on the bolts?
Old Apr 14, 2003 | 01:45 PM
scorp508's Avatar
scorp508
Default Re: (devilfish)
I just logged onto my Alldata.com account (which uses the Helms info) and it states...
1986-88: Long & Medium bolts, 65 Ft. Lbs.; Short bolts, 60 Ft. Lbs.
I put a glob on my finger and spin the bolt threads against it so that the threads fill level and nothing else.
Old Apr 14, 2003 | 01:48 PM
65Z01's Avatar
65Z01
You should follow the torque level for your year; as I said you have higher CR than earlier L98s.
Old Apr 14, 2003 | 01:49 PM
devilfish's Avatar
devilfish
hmm 86-88 wounder if it differs from my 91?
To head bolt torque
