You can get a book but it is fairly easy... Just remove the valve covers.. take off the rockers compress the springs remove the keepers. Pull the springs off and pull the seals out and put new ones in then reverse the steps.. torque the rockers to the proper specs and replace the valve covers with new gaskets and your off and running again smokeless this time.
