need quick answer - minimum rotor thickness
Old Apr 15, 2003 | 02:14 PM
sraft's Avatar
sraft
Default need quick answer - minimum rotor thickness
I have the J55 brakes and need to know the min. rotor thickness for both front and back rotors.
thanks in advance,
Steve
Old Apr 15, 2003 | 04:18 PM
jimswhite92's Avatar
jimswhite92
Default Re: need quick answer - minimum rotor thickness (sraft)
The rotors should have a discard dimension cast into them. My book on my 92 says minimum is .744" and discard at .724".
Old Apr 15, 2003 | 04:28 PM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
Default Re: need quick answer - minimum rotor thickness (jimswhite92)
The .744 and .724 are for standard rotors (both front and rear). The J55s numbers are 1.059 and 1.039. The J55 set up uses standard rears. :cheers:
Old Apr 16, 2003 | 08:43 AM
sraft's Avatar
sraft
Default Re: need quick answer - minimum rotor thickness (Ramrod92)
Thanks guys,
I brought them in to work to measure (we have a machine shop), but the rotors were pretty rusty and I couldn't read the numbers from the casting. Turns out I'm 0.020" over the discard thickness, so I don't have enough meat to machine them, but I can throw them back on. I was planning to install Porterfield R4S brake pads, but I won't do that until I get fresh rotors. While I've got everything apart, I've found more parts that need replacing (busted crown gears on the FX-3 shocks, 2 FX-3 actuators with busted plastic gears and a bad rear bearing/hub), so I would rather not spend $350 on rotors right now.
Steve
Old Apr 16, 2003 | 08:55 AM
jimswhite92
Whoops.... Overlooked the J55 option. Glad you were able to measure and got the correct info.
Sounds like you have somewhere to spend that tax refund.
To need quick answer - minimum rotor thickness
