vibration
Old Apr 16, 2003 | 04:05 AM
jtfrog's Avatar
jtfrog
Default vibration
I just had an alignment and tire balancing and help the vibration a little bit. The vibration diminishes substantualy when i let my foot of the gas. Any ideas whats causing vibration
Old Apr 16, 2003 | 07:53 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Default Re: vibration (jtfrog)
Hmm... does the vibration coincide with RPMs or MPH? Can you replicate this in a lower gear? How about with the clutch in or out? Need more info...
Old Apr 16, 2003 | 08:09 AM
jtfrog's Avatar
jtfrog
no clutch have auto. Does it around 70 mph
Old Apr 16, 2003 | 08:12 AM
Mike_'s Avatar
Mike_
Is it an auto transmission? Try shifting into neutral when the vibration starts and see if it goes away. We had a vibration in our van that got worse as you pushed on the gas, it turned out to be a bad torque converter.
To vibration
