Would appreciate a heads up in finding where the "Tone Generator" is
located and any special information on how to remove and replace. What are the common problems that have been found that would cause them not to work all the time and what else they can effect.
On my '96, the tone generator is separate from the PCM and CCM. It is located above the PKE module, behind the DIC. You probably have to remove the dash pad to access.
