Power window not working
Old Apr 16, 2003 | 01:09 PM
seenalot's Avatar
seenalot
Default Power window not working
Right power window on 1989 stopped working. Checked switch and circut breaker/fuse and that's ok. Is there any other easy fix or do I need new regulator and motor For $250.
Old Apr 16, 2003 | 07:45 PM
don hall's Avatar
don hall
Default Re: Power window not working (seenalot)
Your post does not state if you have tried to operate the RH window with the LH switch?
Old Apr 16, 2003 | 08:29 PM
seenalot's Avatar
seenalot
Default Re: Power window not working (Oldman)
Flip the switches last weekend. Left window works fine with either switch. Was hoping it was only a $7 switch but appears not.
No movement, hear a slight "click" from door but no results!
Old Apr 16, 2003 | 08:53 PM
don hall's Avatar
don hall
Hope you can read my emailed dianostics.
Old Apr 16, 2003 | 09:00 PM
Preacher's Avatar
Preacher
Cruise-In IV Veteran
Can I get that email too? I just started having intermittant problems with my passenger side window too..... Hmm....
Old Apr 16, 2003 | 09:02 PM
don hall's Avatar
don hall
Default Re: Power window not working (Preacher)
On the way. You may need a magnifying glass, or enlargement feature................
Old Apr 16, 2003 | 09:18 PM
Preacher's Avatar
Preacher
I appreciate it!
I love this forum :cheers:
Old Apr 17, 2003 | 08:23 AM
Bill-35thAnvrsy-88's Avatar
Bill-35thAnvrsy-88
I'd like to get that e-mail too if possible. Driver side window doesn't wanna go up sometimes.
Thanks!
Bill
Old Apr 17, 2003 | 08:36 AM
BADMUDE's Avatar
BADMUDE
Default Re: Power window not working (Bill-35thAnvrsy-88)
If you need a motor......check out Advanced Auto, got mine for $60....(rebuilt).
Old Apr 17, 2003 | 11:15 AM
BIG JIM 54's Avatar
BIG JIM 54
The right window motor on my '87 quit too. I took the assembly out of the door and inspected the motor. It was really corroded inside. The brushes were still good so I just cleaned everything up by soaking it in Lysol Basin, Tub and Tile Cleaner (good for removing corrosion). I oiled it and the regulator assembly, reinstalled it and it works fine.
If you don't want the hassle, check Ebay. There's a guy on there selling new window motors for most cars a lot cheaper than $250.
BIG JIM
To Power window not working
