13'' rotor upgrade what is needed
Old Apr 16, 2003 | 07:48 PM
American Muscle's Avatar
American Muscle
Default 13'' rotor upgrade what is needed
i have a 1994 conv what is needed to upgrade to 13'' rotors
Old Apr 16, 2003 | 07:52 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: 13'' rotor upgrade what is needed (American Muscle)
Obviously, 13" roters, but which ones? are you going C5 brake system or J55?
You will need calipers and pads, also obvious! The J55's may be a direct bolt on while the C5 will require an adapter.
Seee Jeff Kopp at http://www.superiorchevyperformance.com
:steering:
Old Apr 16, 2003 | 08:10 PM
American Muscle
Default Re: 13'' rotor upgrade what is needed (jackdaroofer)
i thought their was an adapter kit so i use can my calipers. I was going to use Grand Sport rotors or any 95-96 rotors .
Old Apr 16, 2003 | 08:18 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
I believe you have to move up to different calipers...the 12"calipers are designed for 12"roters. Sort of makes sense if you think about it!
Even if your calipers and pads fit, you would only be using a portion of the roter and not getting the full benefit available...sort of like installing cheap, junk headlights.
:seeya
Old Apr 16, 2003 | 08:20 PM
VetteRacer282's Avatar
VetteRacer282
I am told the calipers are different, but not sure.
You would need a bracket to space it out further (stock GM item), and rotors. Those are given.
As far as calipers and pads, not sure. Call your Chevy dealer and ask for the part number on both the 13" and 12" calipers to see if they are different. And call your local car parts store and ask if they show a different listing for 12" and 13" pads.
:cheers:
Goodluck
Matt
Old Apr 16, 2003 | 08:23 PM
JasonL's Avatar
JasonL
http://www.superchevyperformance.com/misc/gsbrakes.asp
The above has links to pics showing the caliper differences. The 13" rotor is thicker thus the need for a new caliper.
Old Apr 16, 2003 | 08:53 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Default Re: 13'' rotor upgrade what is needed (VetteRacer282)
The brake pads will be the same, you'll need the brackets, rotors and calipers.
Old Apr 16, 2003 | 09:51 PM
ittlfly's Avatar
ittlfly
Default Re: 13'' rotor upgrade what is needed (Mr Mojo)
You also might add in the cost of 2 steel braided brake lines. Good insurance. There are several 13" upgrade kits out there complete with new lines.
Old Apr 16, 2003 | 09:55 PM
WhiskeyPapa's Avatar
WhiskeyPapa
Default Re: 13'' rotor upgrade what is needed (ittlfly)
Correct me if I'm wrong, but using his stock calipers wouldn't really give him any advantage over what he's got now. ?????
Wouldn't you want to go ahead and get a bigger caliper, so that the pads are bigger, taking advantage of the bigger rotor?
Old Apr 17, 2003 | 10:08 AM
ittlfly's Avatar
ittlfly
Default Re: 13'' rotor upgrade what is needed (WhiskeyPapa)
He can't use stock 12" calipers with a 13" rotor as the caliper will not fit. The 12" mounting bracket for the caliper will not allow the 13" rotor to pass through it, so the caliper can't be installed. 13" rotor = caliper mounting brackets for a 13" rotor.
[Modified by ittlfly, 7:11 AM 4/17/2003]
Old Apr 17, 2003 | 11:01 AM
cyclerage23's Avatar
cyclerage23
http://www.vettebrakes.com/ :nopity
Old Apr 17, 2003 | 04:07 PM
JasonL's Avatar
JasonL
Ideally you would want a bigger caliper/pad, but GM used functionally the same calipers for 12" and 13". As the link I posted shows, it's just wider to accept a thicker 13" rotor.
Even if the rotors were the same thickness, the 13" rotor would be better since the caliper is further out, which means the caliper has more mechanical advantage acting on the rotor.
Old Apr 17, 2003 | 08:14 PM
tuband's Avatar
tuband
Cruise-In I Veteran
If you don't have the J55 option (RPO) then you have 12" front brakes. You can change to the 13" HD brakes fairly easily and it is definitely a worthwhile mod.
You will need new calipers (Grand Sports have "Corvette" stamped on the outside) and new rotors. Pads are the same for either. There is a pin(s) that holds the pads in ... be sure you get new (longer) pins since the 13" calipers/rotors are thicker. You will also need some crush washers since you will have to disconnect the brake lines. This is also a good time to do a complete flush of fluid. Run a search on the forum ... you should find plenty of info about these procedures.
Old Apr 17, 2003 | 11:37 PM
American Muscle
Thanks guys for your help , is it worth it to do this mod
Old Apr 18, 2003 | 01:39 AM
blkmagik85's Avatar
blkmagik85
I remember seeing two different kits in the Corvette Central catalog. One was a 13" front brake kit w/everything needed and the other was called the C5 brake kit or something-I assumed that meant stock C5 equipment.
To 13'' rotor upgrade what is needed
