Pinion Gear Seal Replacement
Old Apr 16, 2003 | 11:24 PM
steve123's Avatar
steve123
Default Pinion Gear Seal Replacement
I have stains about the size of a quarter on my garage floor. Diff fluid I believe due to bad Pinion Gear seal. Corvette repair shop estimates it to be about a 3-4 hr job at standard labor rate of $75 per hr. (said 5-6 hr job if the cover needs to be redone as well) These guys do good work and I can't possibly do this myself. My 85 has only 37K miles and I guess its true that these low milegage vettes can really be more costly in the long run. BTW my heater core went last week and I had it bypassed until I decide if I want heat next winter. What do you think is a fair price to get the job done? Thanks
Old Apr 17, 2003 | 04:48 AM
Joeyvette's Avatar
Joeyvette
Default Re: Pinion Gear Seal Replacement (steve123)
I just got my car back yesterday from the Chevy dealer with a new trans and pinion seal. The dealer charged 23 dollars for the seal and 124 dollars for labor I believe. I'm originally from Smithtown myself and I know everything is more expensive up there. Good luck.
Old Apr 17, 2003 | 07:06 AM
BADMUDE's Avatar
BADMUDE
Default Re: Pinion Gear Seal Replacement (Joeyvette)
IMO....it isnt a 3-4 hour job. I pulled my rear diff, changed my gears and put it back in in about 4 hours. Shouldn't take more than 2. Call around...
To Pinion Gear Seal Replacement
