Window Motor replacement 94 coupe
Old Apr 17, 2003 | 12:28 PM
eagle6's Avatar
eagle6
Default Window Motor replacement 94 coupe
I had both window motors go at one time and need to replace them. I was hoping to find out how to do it and maybe a diagram of the area to aid in my replacing them. If anybody could help me I would appreciate it.
Old Apr 17, 2003 | 12:58 PM
don hall's Avatar
don hall
Default Re: Window Motor replacement 94 coupe (eagle6)
You might try a Chilton or Haynes manual, but a GM manual is preferred.
Old Apr 17, 2003 | 01:15 PM
eagle6's Avatar
eagle6
Default Re: Window Motor replacement 94 coupe (Oldman)
I don't have access to either of those manuals.
Old Apr 17, 2003 | 01:55 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Cruise-In II Veteran
Currently Corvette-less
It is fairly straightforward. Don't plan to change the entire regulator. I just removed my interior door panel, and unbolted the regulator and laid it outside the door. I then separated the window motor from the regulator (3 allen bolts if I remember correctly). The brushes in my motor were worn and the springs behind the brushes were weak.
I just stretched the springs and replaced the motor with the same brushes. That was 3 years ago. The cost was right ($0.00). You may want to try this before going the more expensive route.
~ Purp :thumbs:
Old Apr 17, 2003 | 04:44 PM
meliudaj's Avatar
meliudaj
I have asked that same general question here... I have 2 VERY wobly windows.... I have intentions of taking lots of pictures when I do it... but I'm affraid todo it as I don't know ifI have to buy entire new regulators yet.
Old Apr 17, 2003 | 05:09 PM
PurpleC4's Avatar
PurpleC4
Cruise-In I Veteran
Default Re: Window Motor replacement 94 coupe (meliudaj)
Wobbly windows??? That doesn't require much work at all. Remove the interior door panel, then look for the bumpers that rest against the window at the top of the door (behind the panel). You will see that you can just loosen the nuts and slide the bumpers in against the window until you get the proper adjustment.
~ Purp :thumbs:
Old Apr 17, 2003 | 05:14 PM
meliudaj's Avatar
meliudaj
Default Re: Window Motor replacement 94 coupe (PurpleC4)
I hope your right!! I'm just thinking something plastic in there holding the windows is broken. Haven't actually looked yet.
P.S. I think Rocking would be more correct then wobbly. :conehead
Old Apr 24, 2003 | 05:34 PM
Bill-35thAnvrsy-88's Avatar
Bill-35thAnvrsy-88
Default HELP! Window Motor replacement (PurpleC4)
Yo Purp...Ok, Looks like my window motor may have a problem. I've gotten the door panel off (including the stainless steel panel inside the door) and I managed to get the the motor cover off, but how do I get the whole "window lift" (or regulator) assembly outta the door to look and adjust the brushes? I can see the brushes (unit still in door) but I have to get the unit out to adjust brushes and...put the motor cover back on!
Help...I'm stuck.
Bill
[Modified by Bill-35thAnvrsy-88, 5:35 PM 4/24/2003]
To Window Motor replacement 94 coupe
