new heads or LT4 heads
Old Apr 17, 2003 | 10:43 PM
White LT1's Avatar
White LT1
Default new heads or LT4 heads
should I get new heads, port my heads, or buy LT4 heads? Thanks
Old Apr 17, 2003 | 10:51 PM
GlockLT4's Avatar
GlockLT4
Default Re: new heads or LT4 heads (White LT1)
port lt4's :D Actually, porting your lt1's really well is much better.
[Modified by GlockLT4, 9:52 PM 4/17/2003]
Old Apr 18, 2003 | 01:00 AM
Darkness's Avatar
Darkness
Default Re: new heads or LT4 heads (GlockLT4)
Arent LT4 heads soposed to be better than LT1's??? :skep:
Old Apr 18, 2003 | 01:07 AM
LT4CEZ51's Avatar
LT4CEZ51
The LT4 heads stock are better flowing than the stock LT1's. For maximum effort, the general consensus is that the LT1's can actually be ported to flow better than the LT4s, possibly due to increased material in the head. I won't pretend to give you advice on what to do, however, I will point out that LT4 heads will not work with an LT1 intake manifold without some machine work. If you go the LT4 route, I suggest buying the LT4 intake.
Ted
96 CE LT4 Z51
[Modified by LT4CEZ51, 12:22 AM 4/18/2003]
Old Apr 18, 2003 | 01:11 AM
GlockLT4's Avatar
GlockLT4
Default Re: new heads or LT4 heads (LT4CEZ51)
The LT4 heads stock are better flowing the stock LT1's. For maximum effort, the general consensus is that the LT1's can actually be ported to flow better than the LT4s, possibly due to increased material in the head. I won't pretend to give you advice on what to do, however, I will point out that LT4 heads will not work with an LT1 intake manifold without some machine work. If you go the LT4 route, I suggest buying the LT4 intake.
Ted
96 CE LT4 Z51
you got to it before i could.. i'm kinda busy on the computer.
yes, lt1's can be ported better than stock LT4's. Stock lt1's however don't compare to stock lt1's.
Old Apr 18, 2003 | 10:34 AM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Oh.. I think they do Glock.. I think they do... ;)
Old Apr 18, 2003 | 10:43 AM
GlockLT4's Avatar
GlockLT4
Default Re: new heads or LT4 heads (MarkLT1)
oops.. i mean stock LT4's don't compare to stock LT1's..lol
Old Apr 18, 2003 | 11:31 AM
vader86's Avatar
vader86
Having your current heads ported will be cheaper and theyll flow better than the LT4 heads.
To new heads or LT4 heads
