rotor off by 90deg.
Old Apr 18, 2003 | 01:51 AM
30th b-day's Avatar
30th b-day
Default rotor off by 90deg.
I am in the process of installing my freshly rebuilt L98, When I drop my distributor in, it sits 90 deg. from pointing at # 1 cyl. Any help would be greatly appreciated.
Old Apr 18, 2003 | 02:26 AM
CorvetteZ51Racer's Avatar
CorvetteZ51Racer
Default Re: rotor off by 90deg. (30th b-day)
Get a LONG flat tip screwdriver (if you don't have a pre-oiler attachment for your drill) and reach down the distributor shaft hole and rotate the oil pump driveshaft by 90 degrees.
Old Apr 18, 2003 | 02:28 AM
Mike's 86's Avatar
Mike's 86
Bump the engine over with your finger in the #1 plug hole.
When you feel compression, continue and put damper on TDC.
Install Dist with the rotor pointing to #1 on the cap when fully seated.
You may have to turn the oil pump with a screwdriver to line up the dist shaft.
Hope this helps........... good luck........... :cheers:
Old Apr 18, 2003 | 10:23 PM
30th b-day's Avatar
30th b-day
Default Re: rotor off by 90deg. (Mike's 86)
Thanks guys. I didn't realize that the oil pump drive could turn on it's own
Old Apr 18, 2003 | 10:35 PM
CorvetteZ51Racer
It only can with the distributor out.
To rotor off by 90deg.
