Traction Control?
Old Apr 18, 2003 | 02:59 AM
VetteHawk's Avatar
VetteHawk
Default Traction Control?
Cant find my Black Book, Does all 96s come with it? LT4?
Do I remember right that when you turn the car on TC is on and you have to shut the TC off if you want?
Thanks Guys
Old Apr 18, 2003 | 03:44 AM
Darkness's Avatar
Darkness
Default Re: Traction Control? (VetteHawk)
TC became standard in 94 (correct me if wrong) and 96's had Lt4's on the 6spd and LT1's on the automatics.
Yes, be default the TC comes on every time the car is started.
:cheers:
Old Apr 18, 2003 | 10:37 AM
ShawnZR-1's Avatar
ShawnZR-1
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VI Veteran
St. Jude Donor '03-'05-'06-'10-'11-'12
Traction control (ASR) was standard on every Vette starting from 1992. It is configured to be "active" or on every time the car is started. A fellow forum member has devised a way to disable ASR at startup with a module. Do a search and it should pop up. :cheers:
Old Apr 18, 2003 | 12:55 PM
maduraj's Avatar
maduraj
Yes, it is standard on the 92 and newer corvettes. If you want to have it automatically off, send me an e-mail. I have few of the TC orverride controllers available. :seeya
[Modified by maduraj, 11:56 AM 4/18/2003]
Old Apr 18, 2003 | 02:04 PM
Gareth's Avatar
Gareth
is TC retrofittable to earlier models, i.e. 1988?
Old Apr 18, 2003 | 02:14 PM
GlockLT4's Avatar
GlockLT4
Default Re: Traction Control? (Gareth)
It might be possible.. but i sure wouldn't want to try! :eek: Lots of stuff involved with the ASR.
To Traction Control?
