feed/return fuel line leak?
Old Apr 18, 2003 | 06:16 PM
vetteguy216's Avatar
vetteguy216
Default feed/return fuel line leak?
I am installing a SR base manifold and cannot get pass. side runners off even though all the bolts are out. So I decided to remove the fuel rails since I will have to do it later when I removed the 2 threaded fittings and removed the bracket screws gas was leaking non-stop. how can I stop the gas from coming out. :confused: :cuss
Old Apr 18, 2003 | 06:39 PM
MrNuke's Avatar
MrNuke
Default Re: feed/return fuel line leak? (vetteguy216)
Put a rubber plug on it.. Worked for me..It's not under pressure so you don't need a very tight fit, just something that doesn't let it leak gas past it..
Old Apr 18, 2003 | 06:49 PM
ittlfly's Avatar
ittlfly
Default Re: feed/return fuel line leak? (MrNuke)
The pointed end of a golf tee works well to plug open fuel lines.
Old Apr 18, 2003 | 06:53 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I used a length of proper size heater hose with two hose clamps to stop the oozing while I had the intake off.
Old Apr 18, 2003 | 07:05 PM
SunCr's Avatar
SunCr
Vacuum line caps; I keep an assortment on hand for various tasks.
Old Apr 18, 2003 | 08:08 PM
Bluevette85's Avatar
Bluevette85
There can be some pressure in the tank from the gas vapor. Open the cap and plug the lines as suggested.
To feed/return fuel line leak?
