steering fluid
Old Apr 19, 2003 | 04:59 AM
sfields1's Avatar
sfields1
Default steering fluid
hi,
i have a 92 lt1 zo7 6 speed i bought used with 85,000 miles on the clock, this weekend i'm going to be doing some underhood cleaning (not using water though) and was wondering if i should change the power steering fluid or not to my knowledge it has never been changed and the car is 100% stock, there are no steering problems with the car just wondering if its something i should do if so should i use redlines synthetic power steering fluid and how much would it take.
thanks :flag
Old Apr 19, 2003 | 12:33 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Default Re: steering fluid (sfields1)
:cheers:
hanging to new fluids generally never hurts anything...synthetic power steering fluid is a definite improvement over dino. Synthetic handles the heat ranges better.
I use Amzoil auto tranny fluid
:steering:
Old Apr 19, 2003 | 01:11 PM
Fuzzy Dice's Avatar
Fuzzy Dice
Default Re: steering fluid (jackdaroofer)
:seeya Jack...are you saying you use syn tranny fluid in the power steering resevoir ?
Old Apr 19, 2003 | 08:42 PM
jackdaroofer
Cruise-In I Veteran
Cruise-In V Veteran
Default Re: steering fluid (golfboy1)
:cheers:
:D Yes :D
I have had it in there 5 years now, no sign of "morning sicknes", no leaks!
:seeya at CI4
:steering:
Old Apr 19, 2003 | 09:46 PM
Strick's Avatar
Strick
What ever happened to the days when power steering fluid was red and you could tell if your leak was oil or power steering fluid?
Old Apr 19, 2003 | 09:49 PM
sumoboy's Avatar
sumoboy
Default Re: steering fluid (Strick)
:leaving: Those day's are over.
Old Apr 19, 2003 | 10:49 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
I see your replace the fluid and will up one fluid!
Use GM "Cold Climate" power steering fluid. It's better to use a PS mix as it contains the additives required to properly protect the PS system. GM cold climate mix is not just for cold climates. It's a nice semi synthetic mix with the "right stuff" for your PS system. Trust me on this. I buy it by the case from Jeff Koop.
I know what you are saying Jack, but this stuff is really good.
Pete
:cool:
To steering fluid
