Removing starter bolt
Old Apr 19, 2003 | 02:37 PM
kawboy5792's Avatar
kawboy5792
Default Removing starter bolt
i went under the car to replace the starter last night on my '94, and the long bolt came out just fine, but the short one was on so tight, it almost broke the ratchet extension, and still wouldnt come out. any ideas? :rolleyes:
Old Apr 19, 2003 | 03:26 PM
Klamath Stoogie's Avatar
Klamath Stoogie
Default Re: Removing starter bolt (kawboy5792)
Buy some decent tools? :p:
Old Apr 19, 2003 | 04:01 PM
MarkLT1's Avatar
MarkLT1
St. Jude Donor '04
Get yourself a breaker bar, and a good solid extension.. Mine was on real tight, so I used a 1/2" drive, rather then a 3/8", and had to unbolt the cat from the manifold to get it in there. (just did this last weekend.. :) )
Old Apr 19, 2003 | 04:03 PM
SouthernSon's Avatar
SouthernSon
I used a wobble extension to allow a good bite on the one bolt that is hidden up under. If you aren't familiar with a wobble, it is not cut with squared sides but looks 'swollen' at the attachment end. This allows it to offset at small degrees of angle. (can anyone explain this better, please? :) )
To Removing starter bolt
